How to use Cam jargen.....
Old Feb 25, 2003 | 09:04 PM
BOWTYDE's Avatar
I has a CC305 cam. Most ppl don't know the specs on that cam. When I tell ppl the specs I would say that it is a 279/290 Cam?
Old Feb 25, 2003 | 09:31 PM
Lost's Avatar
Re: How to use Cam jargen.....
That's a HUGE frickin cam.. I think you got your numbers a little mixed up
Sorry, I don't know what the actual numbers are with the 305.
Dr.Mudge's Avatar
On this forum most of the time people talk in terms of .050 specs, which would be 220/230 (on a 114 by default), but if you know the rest it tells them a little something about lobe profile (sort of anyway, obviously not the whole story).
Old Feb 26, 2003 | 12:26 AM
WS6T3RROR's Avatar
the cam he described isnt huge. he's just using different messurements. he's using advertised duration which is usually duration @ .006 or .004 it really depends on who made the cam what mesurement they use. but the most common messurements when talking about cams are @ 50 lift. intake centerline means things to a lot of people who are into cars. and the lobe seperation will help them figure the overlap relative to the cam size.
Old Feb 26, 2003 | 08:40 AM
Lost's Avatar
ah, I see
I understand the significance of intake centerline and Lobe Seperation Angle (LSA) in determining overlap. The duration given at a lesser lift allows you to see the steepness of the ramps, doesn't it? But, I fail to see how duration given at such a low lift could be helpful in any other way. So what am I missing, why bother to advertise duration at such a low lift?
Can someone clarify?
Old Feb 26, 2003 | 12:59 PM
WS6T3RROR's Avatar
yes, by comparing the low lift and the lift @ 50 duration you can see how fast the ramps are. the reason for giving advertized duration is sometimes with smaller cams zz4, 210/224 crane etc etc the overlap @ 50 will be a negative number. most people arent far enough into how cams work and what all the terms mean to give much of a **** about what the icl is or anything else besides the max lift and the duration @ 50.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
