how tight to tighten valve covers?
Old Jan 25, 2004 | 10:37 AM
anasazi's Avatar
i replaced my gasket on my passenger side valve cover, how tight should bolt it down?
right now its down hand tight with a small cresent wrench, but not nearly as tight as i could get it if i used a bigger tool or put my back into it.
Old Jan 25, 2004 | 10:44 AM
AsianSensation's Avatar
106 in-lbs. But it's not very critical. I don't think I used a torque wrench on them.
Old Jan 25, 2004 | 10:48 AM
jkipp84's Avatar
If you don't have a tq wrench, just snug them down. You don't want to get gorilla with them because they'll just start caving in the valve cover/possibly messing up the gasket seal. Tighten the inner ones, then the outer ones, then go back and recheck the inner ones, etc. Check them again later as needed.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 29, 2014 04:54 PM
