Cam swap question
Old Jan 25, 2004 | 11:14 AM
NAZTLT1's Avatar
Cam swap question
Can I run a short dowel pin with a 96-97 vented opti? Here is why I am asking. My stock cam has the long dowel pin. I bought a used cam and it has the shorter pin. I was told by a friend that as long as everything is lined up perfectly you don't even need a dowel pin cause the cam runs off the timing gear/ sprocket. Is this true ?? Would like your opinions. I tried removing them already (PITA) next to impossible. I figure if I don't need one why bother.
Old Jan 25, 2004 | 11:15 AM
AsianSensation's Avatar
The dowel is what runs the opti. Yes it need to be long ~.620.
Old Jan 25, 2004 | 11:31 AM
RamAir95TA's Avatar
What Wing said.
The cam dowel pin is what drives the optispark; nothing else. The pin needs to extend about .620" from the camshaft face. Too long, and you'll destroy the rotor inside the optispark. Too short, and you won't drive the optispark.
Old Jan 25, 2004 | 11:36 AM
ibanez6rg's Avatar
Put the pin in a vise and twist it out. They come out pretty easy and you can just tap a longer dowel pin in.
Old Jan 25, 2004 | 11:38 AM
RamAir95TA's Avatar
To add to that, make sure you don't maul the pin if you plan on reusing it.
Old Jan 25, 2004 | 11:46 AM
NAZTLT1's Avatar
I kinda thought the pin was needed but the person who told me has way more experience than I do. Glad I got a second opinion here.
Thanks for your quick responses.
Old Jan 25, 2004 | 12:11 PM
The pin is only important for the LT1 vented opti. No other SBC type engine seems to care.
chuyz28
Jan 15, 2015 04:14 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
