how to test a opti with a mutimeter??
Old Apr 6, 2008 | 08:58 PM
FireChicken1995's Avatar
if this is the wrong place im sorry...
im currently trying to start my car right now with XFI and its throwing a 128 code that is pretty much saying there either isnt a crank signal or its at the wrong time...
is there a way to check the opti with a multimeter? if so how? im using a stock opti that has been sitting in my garage for almost 2yrs so it might be bad but i donno. if anyone can tell me that would be cool. thanks in advance.
Old Apr 6, 2008 | 10:01 PM
128? There is no DTC 128 for a 1995. I don't know of any way to test one with a meter.
Old Apr 6, 2008 | 10:02 PM
He has a FAST XFI aftermarket ECU.
Old Apr 7, 2008 | 05:42 AM
Guest47904's Avatar
Guest
With 12 volts on the red wire (pin C) and ground on the pink/black wire (pin D). You can measure a step from 0 to 5 volts and then back to 0 volts on both pin A (red/black) wire and pin B ( purple/white wire) to the same ground pin. You must however turn it very slowly to see the transition on pin B.
Old Apr 7, 2008 | 06:49 AM
Oops. I didn't catch that.
Old Apr 7, 2008 | 07:11 AM
speedy thanks, il go see whats up with the ole opti today after work and pray its still good.
shoebox sorry to throw you off. bet you dont have a wire schematic for this application do you?
Old Apr 7, 2008 | 07:17 AM
The_Bishop's Avatar
I wouldn't bet against it...
Old Apr 7, 2008 | 07:22 AM
No problem.... typed the same response you did, but somehow the light bulb came on just before I hit the "post" button.
Old Apr 7, 2008 | 09:08 AM
No joy on this one, sorry.
Old Apr 7, 2008 | 09:05 PM
conclusion...... yea the dreaded opti strikes again.
i pulled the opti apart just now and found oil under the silver piece that is between the opti sensor and the rotor. pulled the sensor off and found oil on the inside where the wheel goes in damn opti
Old Apr 8, 2008 | 05:23 AM
Guest47904's Avatar
Guest
not necessarily the optis fault
Usually when oil gets into the opti, it's the fault of the seal in the timing cover. NOT the opti.
Injuneer
Dec 15, 2014 09:36 AM
naaz90
Jul 27, 2002 08:22 AM
