how to test MAF sensor?
Old Jun 18, 2003 | 06:59 PM
anasazi's Avatar
is there some way to test the MAF sensor? i'm wondering if its the reason for my randomly rough idle, crappy gas milage, and low BLM's
Old Jun 18, 2003 | 07:48 PM
slopokrodrigez's Avatar
No real good way to test it since it responds to the PCM with a different frequency depending on how much current is needed to keep the wire at a certain temperature. As air flow increases more current is needed to keep the temperature constant. The MAF responds with a certain frequency response. The PCM uses this feedback to calculate the grams per second of air entering the engine.
You can try disconnecting it and the PCM will go into speed density mode. It will use the input of the MAP sensor, the low resolution signal of the distributor and IAT to determine injector pulse width. You could also try cleaning it with tuner cleaner spray from radio shack.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
3TAS4ME
Apr 15, 2015 02:24 PM
QuickSilver02
Apr 7, 2015 11:12 AM
pete53
Dec 9, 2014 07:31 AM
