how to test guage cluster
Old Jan 16, 2005 | 09:53 PM
krisiun's Avatar
I have a 93 z28 and my speedo has never worked (bought it used). I have tried changing the VSS and it didnt help. The entire guage cluster works execpt for the speedo. Previous owner said that the speedo worked on and off, but I have never seen it work. Is there a way to test the cluster? Also, the car will throw an SES code of 24, which is related to the vss. Any Ideas?
thanks
Old Jan 17, 2005 | 12:07 AM
Seal's Avatar
Re: how to test guage cluster
maybe its not the sensor itself, but the wire going from/to?
Old Jan 17, 2005 | 01:42 PM
krisiun's Avatar
ok, does anyone know where the wires from the vss go? I am pretty sure it goes straight to the ecu, but what pin? I checked shoebox's website, but couldnt find any reference.
Old Jan 18, 2005 | 05:08 AM
slopokrodrigez's Avatar
Yellow wire goes to pin 32 of the red PCM connector and the purple goes to pin 31 of the same. Check for opens, shorted to ground or shorted to each other.
Old Jan 18, 2005 | 07:29 AM
The 1993 uses an ECM that is different from 1994-1995.
Brown connector "D"
Pin
D1=VSS ground (purple)
D8=VSS output to cluster (dark green/white)
D12=VSS signal (yellow)
A problem with any of these can cause a DTC 24.
Old Jan 18, 2005 | 03:29 PM
krisiun's Avatar
cool, thank you very much, I need to go check it
Old Jan 19, 2005 | 05:56 AM
Brown connector "D"
Pin
My bad, gotta get a 93 book someday. Thanks Rob
Old Jan 19, 2005 | 09:02 AM
Zepher's Avatar
helms is having a sale on shop manuals, the same the dealer uses, $30 for 95 and prior vehicles excluding the Vette.
www.helminc.com
KYWes
Jun 14, 2022 06:52 AM
karpetcm
Aug 14, 2015 03:02 PM
KYWes
Aug 10, 2015 07:03 PM
alphaauto
Jul 26, 2015 04:40 PM
asilomar244
Jul 12, 2015 05:53 AM
