How to tell if timing chain is good?
Old Dec 5, 2007 | 05:41 AM
  #16
Guest47904's Avatar
Guest
Gona need to see written proof of that
Originally Posted by mpsalmon
The timing chain will break and the lt1 is an interferance motor and then you are going to bend valves and possibly tear up some pistons.
Never knew a SBC to be an interference engine. You are the first to mention it. Sorry but you are going to have to provide some other proof of that other than your word.
Old Dec 5, 2007 | 11:18 AM
  #17
B-Rad420's Avatar
Also wondering...
Old Dec 5, 2007 | 01:38 PM
  #18
ramair96ws6's Avatar
i can usally tell its good when i take it out of the box from summit racing. being cheap always costs more......
Old Dec 5, 2007 | 01:39 PM
  #19
raroz28's Avatar
timing kits should be part of a 100k tuneup
Old Dec 5, 2007 | 03:12 PM
  #20
zx1216's Avatar
Go with a small block double roller chain, its 75 bucks and is much nicer than the stock chain. You allready have the E-water pump so why not.
Old Dec 6, 2007 | 05:20 AM
  #21
slopokrodrigez's Avatar
Where do some people get this crap from????
In 40 plus years have been around several that have either jump time, broke a tooth or broke a chain. Never seen damage to the bottom or the top on a stock engine.
I don't know, maybe it's the water. LOL
Old Dec 6, 2007 | 09:24 AM
  #22
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
That's comforting to know. I bought a new stock timing set, but didn't bother putting it on. And I've already changed the water pump & opti seals in my timing cover, so I don't really want to put it on now. My car has about 100K miles on it. It's nice to know that if the original timing set fails, it's not going to ruin my engine.
Old Dec 6, 2007 | 04:06 PM
  #23
8cylinders>4's Avatar
where do you get your crap from, the lt1 IS an interference engine why do you think its not? dont get lt1 confused with other chevy 350's that had 78 cc chambers because those are different animals, small chambers, flat top pistons you better believe that engine will chew up some valves if they remain open when the chain breaks
have you ever replaced the valve springs on an lt1 using the TDC method, those valves dont drop very far before the piston keeps them from going any further
Old Dec 6, 2007 | 04:12 PM
  #24
'94 Bad A Z28's Avatar
Originally Posted by shoebox
It might be hard to tell, since stock LT1s seem to have a lot of slack even with new chains.
That's weird, no chain I have put on my car has had any slack in it really... my stock chain with 120K on it was extremely tight, which I thought was odd.
Old Dec 6, 2007 | 04:40 PM
  #25
Guest47904's Avatar
Guest
It's time to lock this thread. The person has their answer.
If anyone wants to debate interference or not, they need to start a new thread.
Old Dec 6, 2007 | 05:40 PM
  #26
biggrizzly's Avatar
I just bought a new stock GM chain, and gears a couple of weeks ago and installed them. The new chain had a fair amount of deflection in it. I really couldn't tell a whole lot of difference from the 150k mile original chain it replaced.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
