$3000 help me decide
Old Dec 6, 2007 | 11:12 AM
clcam97's Avatar
ok guys i need some suggestions,i got $3000 bucks to spend on my car,i drive my car 3 days a week,and i go to the track about twice a month.this are my current mods on my 97z m6, LTs,MT drag radials,cai,km,lowering springs,stg3 clutch,fidanza flywheel,bypass,taylor wires,short shifter and a few weight reductions. my car has 157k miles engine its all stock. i dont care if affects reliability i just want to be faster at the track,any help i will appreciate,thanks!
Old Dec 6, 2007 | 11:24 AM
daonlydino's Avatar
Check out what lloyd elliot has to offer. http://www.eportworks.com/
Old Dec 6, 2007 | 11:27 AM
daonlydino's Avatar
Also you may want to look into some more suspension mods, now torque arm, panhard bar, lower control arm, strut tower brace, and subframe connectors. Sorry for the doulbe post.
Do you do drag, autocross or what?
Old Dec 6, 2007 | 11:37 AM
97formulakid's Avatar
with 3000 you could easily pick up a LE2 package and then do some supporting suspension mods.
Old Dec 6, 2007 | 11:42 AM
Vicious95Z28's Avatar
Agreed with both of these. Suspension is going to be [B][I]VERY[I][B]important, especially when you bump the power. I kinda found out the hard way this year how important it really is. An LE2 with the supporting mods is just plain hard to beat. I'm trying not to be too long winded here but there are a few guys here with LESS is More, ABA383 (ALAN) and James with the red Bird are good examples.
The LE2 is simple, affordable, yields good results and you don't have to make every major mod in the book to make it happen. If you're gonna yank the engine apart and bore/change pistons then I think even Lloyd himself would say go for the best heads you can afford and from his line that would be LE3's. I said change pistons b/c LE3's won't work with stockers (the valves are too big for the valve reliefs in the pistons)
Suspension wise, you already have good a tire it sounds like (M/T DR's) so you could benefit from some good lower control arms and LCA relo's. They would prolly get you by for a while until you could save the $$$$ for a torque arm. Also SFC'S, pretty self explanatory, there's no need in busting a good car apart b/c you're too cheap to tie the car together + the suspension can benefit from ridding chassis deflection.
I hope this helps.
Old Dec 6, 2007 | 11:49 AM
FYI, my LE2 kit with the stock bottom end put down 403 RWHP. I like the driveability and sound of this car sooo much.
Also, I have some month old UMI red non-adjustable control arms for sale if you want them. 100 shipped.
Old Dec 6, 2007 | 01:08 PM
clcam97's Avatar
so i can use the LE2 kit with my stock bottom endwithout harming my engine?and 97formulakit i'll buy those lca form you,you got some pics?
Old Dec 6, 2007 | 01:20 PM
ZL1modified's Avatar
Ford 9 inch with 4:11's...
These post always turn into arguments!
Old Dec 6, 2007 | 01:34 PM
95z28man's Avatar
With 157K on your stock block, your playing with fire big time. It won't harm your engine JUST because you swap, plenty of LT1 owners put that same h/c on the stock block. But with your mileage, it's definately a gamble. Be ready to rebuilt when it blows. But your other option is to hold off and buy a new block and build it up while it's outside of the car, then swap the whole thing in all at once and you know your set if you didn't cheap out on anything. I just put the LE2 kit on my stock block with 97K, and I'm still working on getting it started, but I look forward getting it done.
Old Dec 6, 2007 | 01:40 PM
Yeah, my car had around 75K when the guy did the swap so with 145K I think you are going to be taking a gamble. Sorry I didn't realize you had that many miles on the car.
I'll have to take some more pics, I have some crappy pics of when they were on the car but I'll get some good ones tonight.
Old Dec 6, 2007 | 01:46 PM
clcam97's Avatar
thats cool!i'll check on those pics tonite. any more suggestions anyone?
Old Dec 6, 2007 | 01:49 PM
Old Dec 6, 2007 | 02:38 PM
LT-x7's Avatar
Nitrous!
Then save the rest of the money for a rebuild.
Old Dec 6, 2007 | 02:49 PM
clcam97's Avatar
the ford 9' its a good idea but im just gonna wait until it blows,i did some research and what do you guys think of this;the new edelbrock airgap intake $400,pcm tune,1,6rr,lca,relo brackets,52mm plate,pullies,and a small shot?
Old Dec 6, 2007 | 03:57 PM
shadsta's Avatar
advanced induction more helpful to me than eportworks
