how to tell if O2 sensor is bad
Old May 22, 2004 | 01:04 PM
Got-LT1's Avatar
I just pulled my header and checked the 02 sensor (damn blown head gasket ). How can you tell if it is good? I had an exhaust leak I didn't know about on that side and the back of the o2 (faceing the muffler) is carbon covered while the front (facing front of car) is white. Is that normal?
Old May 22, 2004 | 03:45 PM
OBE1 95Z28's Avatar
A scan tool such as Diacom can be used to verify the O2's. The sensor should cycle rapidly between 100 and 900 mV. Dead sensors will read a constant 450 mv; worn sensors will slowly cycle. If you have 50K+ miles on them, I'd suggest you just replace them. As they "wear", they cause you to burn rich and eat gas mileage.
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
