How to set IAC
Old Aug 16, 2005 | 02:25 AM
Steves396lt1
Guest
Posts: n/a
How to set IAC
Putting in new IAC, need to know how to set it. Pinion depth, counts after start up? This is in a 396 with 230 degree duration cam idleing around 950. ANy help would be appreciated.
1993 Motor with 58mm T Body.
Old Aug 16, 2005 | 02:36 AM
JP94Z's Avatar
Re: How to set IAC
See if this from Shoebox's site answers your question. Or are you talking about actually setting a value in the ECM?
Old Aug 16, 2005 | 06:30 PM
Steves396lt1
Guest
Posts: n/a
Re: How to set IAC
I am talking about when you get a new one, what are the mesurements and procedure for putting one in. ALso, what counts should be read when running hot and cold.
Old Aug 16, 2005 | 10:06 PM
T/A KID's Avatar
Re: How to set IAC
Go to Golen engine service (website) they have a write up on how to do this I believe.
Old Aug 16, 2005 | 11:05 PM
Steves396lt1
Guest
Posts: n/a
Re: How to set IAC
Thanks. Which way do you go to increase voltage.
Old Aug 16, 2005 | 11:09 PM
Re: How to set IAC
Increase voltage on the IAC? Are you sure you are not referring to something else?
Reference for counts can be found here (courtesy of Injuneer).
Old Aug 16, 2005 | 11:10 PM
Steves396lt1
Guest
Posts: n/a
Re: How to set IAC
I went to the Golen website, and they have you open the throtle blades for better idle, but you need to adjust the TPS, which mine is adjustable, to compensate for opening the blades, so you need to go down/up depending on what happens
Old Aug 16, 2005 | 11:13 PM
Re: How to set IAC
I assume you will be watching voltage while you adjust, so just turn it whichever way makes the change you desire.
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
