How do I access the wires on the starter?
Old Aug 16, 2005 | 07:27 PM
93 MTI Z28's Avatar
Please help! I need to remove the two nuts that connect the battery wire and solenoid wire to the starter so I can remove it. I don't have any room to turn a normal socket wrench in between the starter and the frame of the car to loosen the nuts. What kind of tool do I need? Please be specific.
Thanks in advance,
Walter
Old Aug 16, 2005 | 07:47 PM
94Z28WP's Avatar
Re: How do I access the wires on the starter?
If I remember correctly, I used a long extension and got to both nuts through the opening between the block and motor mount.
Old Aug 16, 2005 | 07:53 PM
valter's Avatar
I unbolted starter itself first, you can turn it around then, so it will not be hanging on wires Then I removed thin wire, and then carefully thick. Put it back in reverse. Very easy this way.
Old Aug 16, 2005 | 08:00 PM
crazypurgatory's Avatar
Lightbulb Re: How do I access the wires on the starter?
Yep I did the same thing I used a long extension.
I think it was about a foot.
Chris G.
Old Aug 16, 2005 | 11:30 PM
BigJustinZ28's Avatar
I dropped the starter first then undid the wires as well .....
Critter
Jul 7, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Jeff1904
Jan 3, 2015 12:00 AM
pete53
Dec 9, 2014 07:31 AM
