How to replace a starter on 96, lt1
Old Jan 14, 2005 | 02:33 PM
Lightgomez's Avatar
Thumbs up How to replace a starter on 96, lt1
Hey guys...and gals
Im new to all this scene, so please excuse my ignorance when it comes to the mechanics of the car....I have a 96, z28 that i need to change the starter in....Could you please help me out in directions on how to do it....
Old Jan 14, 2005 | 02:35 PM
Hawk's Avatar
Re: How to replace a starter on 96, lt1
first get the haynes/chiltons manual so you have some documentation and it's nice to have if you do anything to your car.
It's real easy
-take off negative bat cable
-jack up car
-take off the wires attached to the starter
-take off the few bolts that hold it on
-pull it off
-installation is reverse of removal
I'd recomend getting a OEM starter if possible, I tried to put in a pep boys remanufactured one once it didn't fit right they wanted me to use shims and crap, I rather get a plug and play OEM if possible.
Brian
Old Jan 14, 2005 | 02:37 PM
"White Knight"'s Avatar
The easiest way for you to do it correctly and confidently is to go out and get yourself a Haynes manual at your local autoparts store for your year. It will have step by step instructions on where it is located and what order to do things in. You will use it a ton and is only 15 bucks.
Old Jan 14, 2005 | 02:38 PM
Man, you beat me Hawk.
Old Jan 14, 2005 | 02:42 PM
Lightgomez's Avatar
Thanks for the advice!!!
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
ScottZ
Mar 3, 2004 01:34 PM
