How to replace the Crank Position Sensor...?
Old Jun 15, 2003 | 09:48 PM
pillagenburn's Avatar
How do i replace the crank position sensor? where is it located? Does it have any bearing on how my car will run? (i.e. a malfunctioning sensor causing the whole drivetrain to buck under load at low rpm). I really need help with this guys ... i dont want to send my motor to an early grave!
thanks...
Old Jun 15, 2003 | 10:35 PM
96z's Avatar
96z
The only thing it does it monitor missfires. Haveing it nonfunctional wont send your car to an early grave. In fact mine is deleted out with LT1 edit.
It is located on the passenger side on the bottom of the timing cover.
Old Jun 16, 2003 | 12:32 PM
did it cause your car to vibrate at all or cause the drivetrain to bounce around under load at low rpm ?
Old Jun 16, 2003 | 09:23 PM
96z's Avatar
96z
No the sensor just detects misfires, nothing else, It wont cause any of those symptoms. Did you check your motor and tranny mounts, they maybe the culprit.
Old Jun 16, 2003 | 10:02 PM
acutally, i think its my MAP sensor - i unplugged my MAP sensor and it had all of the same crap go wrong with it. I guess its not getting enough fuel - well, i'll just replace it and see how things go...
any other input would be much appreciated...
thanks!
Old Jun 16, 2003 | 11:12 PM
96z's Avatar
96z
What about your MAF?
Old Jun 17, 2003 | 02:49 PM
MAF sensor is fine - i unplugged it and the car barely ran. I think some of the plug wires got crossed around or something
....ill check it out - thanks for your input tho
Old Jun 17, 2003 | 08:03 PM
Originally posted by Killerjello
on a 3800 the crank position sensor does MUCH MUCH more than detect misfires its the whole basis of ignition timing.
Of course, this is not on a 3800 and not an lt-1, but still thought it was useful, since some people argue that that is the only thing any crank position sensors do
theres my useless post for the day
Very true. Most other cars won't even run without the crank position sensor.
Now, if we were only talking about those other cars....
HectorM52
Jul 30, 2017 11:46 AM
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
