How to remove the spark plugs?
I just got done putting a tune up on my 96-z. And I got most of the spark plugs out without a problem. But the rear two on the right bank was a SOB!!!!Is there a trick to this or a special tool made? My arms are too big to fit up there and my wifes arms didnt fit either. So we used a 11 year old with small arms to get those out! I know the GM dealers dont use kids or go looking for folks with small arms to do this task. So whats the trick? Also replaced my opti spark and I'll be darned if it still doesnt stall. Replaced the coil, and icm. What I have found is that when it stalls, I remove the air duct between the mass air sensor and the air filter and it fires right up! Whats up with that?
P/N: 30102
Click For Larger Image
$29.95
QUANTITY IN CART: 0
Installer Lookup
1998-2002 F-Body
1993-1997 F-Body
1982-1992 F-Body
2007-2008 Mustang
GT 500
2005-2008 Mustang
1994-2004 Mustang
1986-1993 Mustang
2004-2008 F150
2005-2007 Dodge Charger/Magnum/300C
2004-2005 Dodge Ram
2004-2006 GTO
2005-2008 Corvette
1997-2004 Corvette
1992-1996 Corvette
1985-1991 Corvette
GM Truck and SUV
2005-2007 Cobalt SS
1997-2006 W-Body
1994-1996 Impala SS
1998-2002 Camaro SS
1998-2002 Firehawk
1996-1997 Camaro SS
1993-1997 Firehawk
Wheels and Tires
Accessories
Wearables
Gift Certificates
1501 Industrial Way North | Toms River, NJ 08755 | Phone: 732.349.2109 | Fax: 732.244.0867
Spark-Plug Socket, Modified to work with headers (1)
In order to make spark plug removal a little easier in the crowded F-car engine compartment; SLP has developed this modified spark plug socket. Cut down to fit into extremely tight areas; the socket has had the square drive removed to allow the plug to protrude. The socket is turned using an open or box end wrench on the hex base.
NOTE: Due to the current cost of order processing, SLP has instituted a $25.00 minimum order requirement.
$29.95
QUANTITY IN CART: 0
Installer Lookup
1998-2002 F-Body
1993-1997 F-Body
1982-1992 F-Body
2007-2008 Mustang
GT 500
2005-2008 Mustang
1994-2004 Mustang
1986-1993 Mustang
2004-2008 F150
2004-2005 Dodge Ram
2004-2006 GTO
2005-2008 Corvette
1997-2004 Corvette
1992-1996 Corvette
1985-1991 Corvette
GM Truck and SUV
2005-2007 Cobalt SS
1997-2006 W-Body
1994-1996 Impala SS
1998-2002 Camaro SS
1998-2002 Firehawk
1996-1997 Camaro SS
1993-1997 Firehawk
Wheels and Tires
Accessories
Wearables
Gift Certificates
The modified SLP plug socket helps. I have never tried to do plugs on a car without headers but it seems that it would be much worse. It is not the easiest thing to do with headers. Another trick is to get the back 2 is to go at them from underneath after removing the starter.
You should include a "signature" with your post with the year of your car engine, transmission and any mods so people know exactly what you are working with... It helps people give accurate advice.
It depends on the headers. I have the "smog-legal" headers which are small but are better than nothing. It is a royal-pain to get those plugs out. It took me 6 hours with a special socket tool and a gear-drive wrench.
I'm turning in my TR55s (coppers) today for some Iridiums... I'm not going through this again for a while.
Not all headers are the same, some are really easy. It's just the CARB approved one's are difficult. IMO
Mine are a little difficult i have pacesetter mids. But I also have skinny hands. I use a regular 5/8 plug socket and a 3/4 ratcheting wrench. I can get all from the top but #5 & #7 are easier from the bottom.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
