how to remove a/c from 93 z28?
Old Jun 15, 2008 | 11:35 PM
93camaroLT1's Avatar
I pulled out the condenser, compressor and all the other crap. Then, I did a search and see that people are running a a/c delete pulley. How does this work (i.e. what does it bolt onto) (pictures would be nice). Do I really need a pulley there.. can't I just buy a smaller belt and eliminate that pulley all together?
Old Jun 16, 2008 | 05:15 AM
Look at the routing diagram for the serpentine belt, and then the front of the engine, and you will understand why you can't just run a shorter belt. The "1LE" A/C delete pulley comes mounted on a bracket that bolts to the holes where the compressor would normally bolts. There were two different A/C clutch pulley diameters, so some people have to get a different belt length even with the delete pulley, and others use the stock belt.
HectorM52
Jun 23, 2016 08:42 PM
alphaauto
Jan 23, 2015 07:42 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
pologreen97z
Dec 2, 2014 10:42 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
