How to put a CSI WP ???
Old May 10, 2006 | 11:30 PM
mannycamaro's Avatar
From: San Juan Puerto Rico, Look it up it's in the Caribean
Question How to put a CSI WP ???
Hi, I would like to know if is easy put
to my Lt1 the CSI Electric WP ???
I am from Puerto Rico and here the mechanic want
$ 340 for that labor ...
Help me if know >>>??? These is a hard work ???
Old May 11, 2006 | 01:13 AM
luckyou03's Avatar
Re: How to put a CSI WP ???
pulling the water pump is a pita. Then you need to drive out the mechanical shaft. plug the hole. installing the pump in the housing is easy. You'll the need to notch the fan shroud for it to clear. Bolt it back up, refill the coolant and bleed the system. Wire it up with a fuse and 30amp relay.
1-10 maybe a 5?
Old May 11, 2006 | 02:08 AM
zx1216's Avatar
yeah, you will probably need access to some sort of press, a plug and maybe a file or die grinder to notch the housing. I work at my schools machine shop so i turned the plug out of aluminum, pressed it in and ground the housing in maybe 2 hours.
Old May 11, 2006 | 06:26 AM
GetaZforgetGT's Avatar
Take a look at this link.
http://ken.lowrance.com/projects/CSI...mp/Default.htm
Old May 11, 2006 | 07:34 AM
Javier97Z28's Avatar
Moderator
We found a sanding wheel on a dremel, oddly enough, was the perfect thing for making the notches on the water pump.
As for driving out the driveshaft.. that's a pain in the ***. I didn't have access to a press so I used my air impact hammer with a chisel bit.
Old May 11, 2006 | 11:26 AM
Hey!
Now I seen that not is easy install the water pump
I think I will pay the $ 340. for the mechanic do the job
Thanks !!!!!!!
Old May 11, 2006 | 01:09 PM
luckyou03's Avatar
hope he's gonna wire it for you
Old May 11, 2006 | 01:15 PM
jsetzer's Avatar
Impella(sp?) pops off easily with a prybar
Then hammer the shaft out.
Dremmel etc to cut the notches.
Done.
Old May 11, 2006 | 02:07 PM
Bawls's Avatar
Save some money do it yourself, I did it when I was 18 with the instructions GetaZforgetGT posted.
Heathen1
Jan 2, 2016 04:27 PM
HarleyZ28
Oct 5, 2015 06:23 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
lbrowne
Nov 13, 2011 04:25 PM
