Madz28.com Thank You!
Old May 4, 2006 | 03:10 PM
torchred96's Avatar
Hey guys, in case you saw my other thread about Ion not responding to my emails, He did get back to me and explained an unfortunate set of circumstances and told me that I should have already gotten the Computer.
anyway, I just want to say that it did arrive yesterday, and I put the comuter in my hotcammed lt4 a4 (motor is from an lt4 transplanted in my lt1) 96 vette and it is a completely different running/shifting and more powerful car..Much more so than I ever would have imagined a tune could do.
I do appreciate everything he did to make things right, but most of all, I appreciate that my car runs and should run awesome for a long time.
Now, I don't have a check engine light staring me in the face, my shift points are higher and much firmer (but not too hard if that makes sense) the rev limiter doesn't interupt the shift process like it did before as he set that higher too. He deleted the scan of my rear o2 sensors and egr (which I am now going to remove...I had put it on the lt4 hopefully to avoid codes), and also, he programmed the car for more performance from the lt4 injectors, which i have yet to install, because I had the lt1 rail already on the car. So I'm excited that there's prob. even more in it after I install the 28lb injectors/rail.
Anyway, I am completely satisfied with the turn out of the computer and what he did. I'm sorry I got a little frustrated. But fortunately, all is well..and even better than i expected.
thanks again.
sam
Old May 11, 2006 | 11:58 AM
transAMdriv3r's Avatar
Re: Madz28.com Thank You!
i am just curious, if you get the madz28 tune will it stop my car from hesitating when it gets warm.
Old May 11, 2006 | 02:09 PM
Bawls's Avatar
He was very fast in getting my pcm socketed, and programmed. Car runs a lot better now.
Old May 11, 2006 | 02:11 PM
Bawls's Avatar
If you're runnin on stock tune and you're bone stock, then I doubt it. It's something mechanically related. But give him a call and find out.
tonylittell
Sep 19, 2005 06:31 AM
madwolf
Dec 7, 2004 06:01 PM
pillagenburn
Oct 26, 2004 04:28 PM
johnny o
9
Sep 16, 2003 02:08 PM
Camaro_Maniac63
May 26, 2003 09:50 AM
