how to Port out and polish intake.. suggestions?
Old Feb 26, 2003 | 05:41 PM
nB5sP's Avatar
i was just wondering what tools i would need to do the whole job and if it's worth it. have any of you guys seen some improvement doing this?
would I lose response if i port out too much?
any help would be appreciated, thanks!
Old Feb 26, 2003 | 06:20 PM
nB5sP's Avatar
another question!
would a dremel be able to handle the job? i ask because i feel that with a dremel it would be easier to be more accurate.
Old Feb 26, 2003 | 06:29 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
porting the heads might give you some power
porting them well might give you some more
do a search, buy a book raise the roof
you might even gain some more with a bigger cam.
Old Feb 26, 2003 | 07:17 PM
nB5sP's Avatar
do you think a dremel would be good for the job? 'm thinking about getting one cause they can do just about anything.
Old Feb 26, 2003 | 07:38 PM
Cory_SS's Avatar
I've attempted to use a dremel but it just doesnt work well compared to a die grinder. Dremels are just too fast for cutting and the tools get clogged. Get a die grinder and run it at 10k rpm's and get some nice beefy abrasive wheels from Home Depot. You'll get way more cutting done, believe me!
Old Feb 26, 2003 | 07:55 PM
RCF925's Avatar
Port them wrong and you will get less power, Do it right more power. If you have access to a flow bench I would flow them to see where your at and then flow them after. It's the only way to know for sure where your at. Just my .02
Old Feb 26, 2003 | 08:05 PM
nB5sP's Avatar
can you give me a couple of examples of mistakes that could cause you to lose power?
Old Feb 26, 2003 | 08:41 PM
PatriotTA's Avatar
If you are going to attempt this, I would exercise caution. If you have any friends that know what they are doing, have them show you, or just keep them around. Die grinder, not a Dremel. Also, use the gaskets for a template. I'm having a friend do mine for me because I'm not comfortable enough with a die grinder yet
Old Feb 26, 2003 | 09:06 PM
cals400ex's Avatar
are you wanting to port the heads or the intake?
Old Feb 26, 2003 | 09:11 PM
nB5sP's Avatar
just the intake for now. i know it would be alot easier than doing heads.
i'm comfortable with doing the job.. i'm just curious as to what to watch out for. or technique.
Old Feb 26, 2003 | 09:13 PM
treyZ28's Avatar
the intake outflows everything in yoursetup right now
you wont gain anything
Old Feb 26, 2003 | 09:32 PM
WS6T3RROR's Avatar
i am fairly certain that raising the runner roof's in the manifold will improve the entry angle into the cyl head port. the injectors get in the way of this though and its a big pain. worth maybe 15hp and thats if you know what you're doing. not worth the time bud.
Old Feb 26, 2003 | 09:34 PM
Cory_SS's Avatar
....exactly! It won't do a bit of good to port the intake when the heads have'nt been port matched. I say go for it if you plan on porting your heads later on down the road, your just not going to gain anything until those heads can keep up with the flow.
Old Feb 27, 2003 | 12:44 PM
BUBBA's Avatar
Would'nt bother. Over port and you may experience reversion. Polish, and you might screw up the atomization of the fuel with the shiney surface.JMHO
Old Feb 27, 2003 | 01:41 PM
BUBBA's Avatar
Pay no heed to my response. I was thinking of something else.
