How often should the Fuel Filter be changed?
Old Apr 29, 2003 | 12:19 PM
JD30thZ28's Avatar
Thumbs up How often should the Fuel Filter be changed?
How often do you guys change your fuel filter and what are the common signs that it has gone bad? Thanks. Like many other LT1 owners, I am trying to locate the source of my low rpm stumble.
Old Apr 29, 2003 | 12:22 PM
Compstall's Avatar
It's a pretty cheap item to change when troubleshooting to help rule out certain items. I change mine annually, and if I ever run into problems, I always know that the fuel filter is more than likely not the problem.
- Brent
Old Apr 29, 2003 | 01:14 PM
Tech's Avatar
12,000 miles
Old Apr 29, 2003 | 01:29 PM
JD30thZ28's Avatar
Thanks guys Hopefully this solves my problem
Old Apr 29, 2003 | 01:43 PM
sideways_Into_3rd's Avatar
block the EGR yet ??
Old Apr 29, 2003 | 04:39 PM
JD30thZ28's Avatar
EGR is blocked off and tuned out, going to adjust the tune some more tommorow night, changing the fuel filter and coil tonight This hesitation better be gone before the dyno day on sat so I can spray
Old Apr 29, 2003 | 04:46 PM
Don 97 SS's Avatar
- Brent
Great advice! I feel the same way.
Old Apr 29, 2003 | 04:51 PM
doodad's Avatar
Agreed I will never let mine go more than a year again. It is like wipers you forget how good it was for so little effort . My car has more pep again.
PCLZ28
Dec 24, 2015 05:19 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
