How much vaccuum should I be pulling?
Old Jul 14, 2004 | 04:18 PM
wicked_95z's Avatar
Curious how much vacuum I should get with a 236/242 cam if the valves are timied right an the tune is good. Not sure if I need to provide any more info
Old Jul 14, 2004 | 08:23 PM
wicked_95z's Avatar
Well I put the guage on the motor at the port the egr valve solenoid was connected to and was pulling between 9 and 11 inches of vacuum. Does that sound about right? On the guage it says that the valve timing is late. I just readjusted my valves yesterday to 1/4 turn past zero lash on Comp R's
Old Jul 14, 2004 | 08:26 PM
RamAir95TA's Avatar
Re: How much vaccuum should I be pulling?
With my XE236/242, I'm pulling 12" of mercury at idle. Not too bad if you ask me.
Old Jul 14, 2004 | 08:30 PM
wicked_95z's Avatar
Cool...maybe a little more tweaking on the valves will get me some more vacuum. Thanks
Old Jul 14, 2004 | 09:04 PM
Just as a side note, the reference you have on your vacuum gauge for timing is meant for a stock cam. A radical cam throws that vacuum reference out the window.
2QUIK6
Sep 17, 2016 02:31 PM
jbert55
Oct 31, 2015 03:52 PM
Dams76
Aug 20, 2015 08:28 AM
Cam's maro
Aug 11, 2015 07:45 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
