How much spray can a 11 to 1 383 take
Old May 24, 2009 | 10:13 PM
stephenpen's Avatar
I went out for a ride in my buddies 95 Turbo Mustang and it was faster then all hell. My 383 now feels slow so I need to give it some spray. I have maybe 1100 miles on complete rebuild. Its a 383 11 to 1 cr with a forged crank, H-beam rods, and Mahle forged pistons. Stock ported heads with big valves ported intake and a cc306 cam. I have a mallory 685 ignition box to pull timing. How much will it take safely.
Old May 24, 2009 | 10:23 PM
Were the pistons/rings selected and set up for a large shot of nitrous? Vague terms like "forged crank" (e.g. - Scat or Callies would make a difference), and "H-beam rods" prevent any sort of meaningful analysis of the ultimate capacity of the engine. Do you have a 4-bolt main conversion?
I spray a 300-shot. See "mods list" for the details.
Old May 24, 2009 | 10:33 PM
stephenpen's Avatar
No it is still a 2 bolt and the Crank and rods are Eagle. Its all I could afford at the time. I would like to start with a 125 and see how that feels. I would think the engine should be good for a 200 shot but I wasn't sure because of the compression ratio
Old May 24, 2009 | 10:38 PM
Nitrous likes high compression ratios. You just have to figure out how much timing to pull at each level of nitrous.
Old May 25, 2009 | 02:09 AM
bombebomb's Avatar
125 shot "should be" safe, what is your ring gap? I have heard horror stories of built engines blowing up on small shots due to set up.
Old May 25, 2009 | 08:09 PM
Josh-'04 GTO's Avatar
I agree. You could start in the 100-125 HP range for starters and work your way up carefully from there.
Old May 29, 2009 | 04:43 AM
stephenpen's Avatar
I spoke with the guy who did the motor and he said he increased the ring gap by .025" for the nitrous. I just bought a Nitrous Express kit last night and I can't wait to try it out. The kit is only good for a 150 shot. Does anyone think that would be too much for the motor. I'm going to retard the timing 1 degree per 50hp. What should I start out with.
Old May 29, 2009 | 02:21 PM
bombebomb's Avatar
The gap is large enough that is for sure.
Old May 29, 2009 | 02:35 PM
DRIVEFASTKEEPLEFT's Avatar
Standard is to pull 2 deg of timing for every 50hp you hit it with.
Old May 29, 2009 | 02:57 PM
omgwtfdied's Avatar
dont do this to your engine. muscle it up
Old May 29, 2009 | 03:29 PM
SnakeSkinner28's Avatar
another great piece of advice found.....
should he put his engine on steroids or HGH.... which do you think would be better to muscle it up?????
Old May 29, 2009 | 04:42 PM
bombebomb's Avatar
Elaborate? People use the juice on stock engines every day, this guy is in a whole new playing field than a stock engine I see no reason for him not to use some.
Old May 29, 2009 | 04:51 PM
He's got a forged rotating assembly, why on earth would he not spray? I say stoke it up!
Old May 29, 2009 | 07:30 PM
Rather than use a "rule of thumb" to retard the timing, get it tuned correctly and let the tuner determine how much timing to pull when you spray. Reading the plugs is really the only way to do it on an engine that is already putting down decent power.
Old May 29, 2009 | 08:50 PM
stephenpen's Avatar
I wanted to give it the juice on the dyno to make sure my A/F ratio stays safe. Camaro Country CC here in Ontario is having a dyno day at redline performacnce on sunday. But instead of putting the kit in today I've been chasing sharks from both sides of the engine. I looks like my wires arced on the alt because of the alt relocation bracket. I think the wires are also hitting the air pump header crossover pipe ? because I have sparks coming off it on the driver side. First I thought it was the rainy weather getting to my opti but it looks like wires. The vacuum hose of the opti which is rubber is arcing off the air pump pipe. I've never seen rubber conduct electicity but its doing it. I think its the Electronics cleaner I spayed earlier that coated the wires. I'm totally lost. If anyone has ever seen this feel free to speak up.
