How Much Should the RPM's Bounce?
I just bought a 93Z with a Comp cam 227/233 .560/.569 and Pro-Magnum 1.6 Roller Rockers. The computer has been done by PCMforless. After it comes to operating temp, and it sits at idle for a minute or two, the RPM's start surging from 600-900, not real fast like Ive seen high performance carb'd engines do, but not extremely slow. This is normal for that size cam?
Im just getting use to the car and the things it dose and the sounds it makes, so I'll prolly have more questions in the next few weeks
Re: How Much Should the RPM's Bounce?
Originally Posted by 1racerdude
Throttle blades been opened?
Sounds like your IAS motor needs cleaning because it can't adjust quick enough.
At least mine dosent bounce all over the place. just 200-400 rpm's. Im gonna be taking to get a dyno tune, so they will taking care of everything.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
