How much to rethread intake threads?
Old Dec 20, 2011 | 05:40 PM
vincent714028's Avatar
My heads have stripped intake bolt threads. I tried to install heli-coils into the holes but I think I got the angle wrong.
One side will screw in but not the other and vice versa. I am considering a used or a new reman engine if cost of the rethread is too prohibitive.
What does a machine shop generally charge to fix the threads?
Old Dec 20, 2011 | 05:51 PM
raroz28's Avatar
Re: How much to rethread intake threads?
The shop I used for my cam bearings and crank polish charges about $8 for a helicoil.
Some shops may be more or less. Why not just call the shop? Helicoils are cheap.
Old Dec 20, 2011 | 06:40 PM
Bersaglieri's Avatar
Are they stock heads, ported, or aftermarket?
Might be better off just getting different heads depending on how bad they are screwed up. If they are stock you could probably get another set for cheap, I have some laying around, let me know.
-Dustin-
Old Dec 20, 2011 | 06:41 PM
Have your heads been milled, possibly throwing the intake manifold bolt hole locations "off"?
Old Dec 20, 2011 | 10:11 PM
The engine was overheated by the previous owner. The block was fine but it needed new heads. So stock new/reman heads were installed.
I think the mechanic did a terrible job. The intake bolts were stripped, the belt was on wrong, and the valvetrain is very noisy.
The intake leaking oil is my reason for doing this. Although, I have removed the engine/trans with the subframe connected because I needed to rebuilt the transmission and noticing the oil leaks motivated me to drop the engine as well.
I don't know if the heads have been milled. Is there a way for me to measure without removing the head? Is there a shim to correct the new angles?
The machine shops I call say they need to see the head first, so no one gave me an estimate. One said I need be cautious about putting new heads on an engine with 130000 miles. He says I can mess up the rings. Is that true?
maybe2fast
Mar 26, 2015 08:34 AM
beaver50
Feb 15, 2015 02:56 PM
squarehead
Jan 15, 2015 07:02 PM
