How much to put a 200R4 in my 94 Z?
Old Aug 20, 2003 | 08:47 PM
ishz28's Avatar
Just wondering, my 4L60E is starting to act up and from what I understand 200R4's are an awesome choice. They're fairly cheap too. Is it a hard install or should I just think about going with a T-56, thanks for your replies.
Old Aug 20, 2003 | 08:55 PM
RCF925's Avatar
You might check your smog laws, I put a 700R4 in my 94 and had to put back the M6 because here in Ca. if the transmission isn't the same year as the car or newer they won't smog it.
Old Aug 20, 2003 | 09:00 PM
Sweetred95ta's Avatar
I've heard of this 200r4 tranny swap. Supposedly they're really strong trannys. Could someone who has done this shed some light on this subject. I'm kind of curious myself.
Benji
Old Aug 21, 2003 | 05:24 AM
ishz28's Avatar
No SMOG laws or vec. inspections in FL.
Old Aug 21, 2003 | 09:55 AM
Xscream's Avatar
Isn't it a 2004R that you want to swap
Old Aug 21, 2003 | 01:40 PM
faded93bird's Avatar
evrey thing is the same as swaping in a th350
the 200r4 is the same overall leangh and uses the same crossmember
the drive shaft would also be the same leangh as well as the torque arm mount needed think you would need a drifferent yolk though as welll as a 92-93 tb and tv cable mount
they can be built strong but they're not cheap by any means ask any GN guys
If there is any thing else i can think of i will chime in later
Faded
Heathen1
Jan 2, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
