How much to put a 200R4 in my 94 Z?
Just wondering, my 4L60E is starting to act up and from what I understand 200R4's are an awesome choice. They're fairly cheap too. Is it a hard install or should I just think about going with a T-56, thanks for your replies.
evrey thing is the same as swaping in a th350
the 200r4 is the same overall leangh and uses the same crossmember
the drive shaft would also be the same leangh as well as the torque arm mount needed think you would need a drifferent yolk though as welll as a 92-93 tb and tv cable mount
they can be built strong but they're not cheap by any means ask any GN guys
If there is any thing else i can think of i will chime in later
Faded
Faded
NewsBot
Dec 28, 2014 06:20 PM
