How Much Of A Problem Is This??????
Old Jan 24, 2004 | 11:40 AM
formula king's Avatar
i think i finally found out what that annoying rattle sound coming from under my car is....the sound comes from under the shifter when im inside the car,
anyways i looked and saw that my exhaust was loose, cuz my buddy said he saw a rattle then it went away then came back......i was wandering would that make a big diffrence performance wise??????????
also sometimes when i give it a little gas i hear it shake and make a slightly diffrent sound then back to normal
Old Jan 24, 2004 | 12:15 PM
would that even do anything
Old Jan 24, 2004 | 12:25 PM
N2OpwrdTA's Avatar
Why not fix whatever it is? Jack up the car, put it safely on stands and fix it. Its probably either a loose, rusted clamp or broken hanger. Just fix whichever it is.
Old Jan 24, 2004 | 12:39 PM
AdamZ1LE28's Avatar
When I put my exhaust on, I had a bat rattle coming from under my car. Right where the exhaust pipe goes over the rear axle, theres a heat shield up against the floor, and the pipe was rattling against this heat shield, which was then hitting the floor of my car and making an awful noise....All I did was put some fire-retardent insulation between the heat shield and the floor. Now the only noise coming from under the car is the rumble
Old Jan 24, 2004 | 12:52 PM
yeah im ganna fix it...but wut i want to know is.....will that make my car run bad (performance wise) at all
Old Jan 24, 2004 | 01:01 PM
lt1g3n's Avatar
yea
if its just the exaust shaking, and rattling, i doubt it will harm any performance, but if theres a hole in the exaust or anything is abnormal about it, then yes.. but seems like you just need to make it tight and not about to fall off .. any how.. i could not drive my car with any sound like that, it annoys me to death and i refuse to drive till its fixed :P, fix it yourself for sure
Old Jan 24, 2004 | 01:14 PM
KCFormula's Avatar
If its bad it might cause a false knock.
Old Jan 24, 2004 | 01:56 PM
N2OpwrdTA's Avatar
Yeah...Fix it not matter what you think its doing. If its rattling that bad, it might be causing false knock conditions...possibly pulling timing, etc and hurting performance. If its an exhaust leak, then youll have poor performance and that annyoing tic sound and nice black **** all on that area of the pipe(s). Just fix it....thats what its trying to tell you to do.
Old Jan 24, 2004 | 03:12 PM
OFF COURSE IM GANNA FIX IT
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
