How much preload do you add?
How much preload do you guys add to your rocker arms? Ive always added 1/2 but there always seems to still be some clacking. Ive always tried to avoid more since I didnt want to bog the car down with too much preload.
What is theoretically best for best power? 0 preload?
Just wondering what everyone had to say before I go adjust the rockers again tommorow.
I made a post like this a while back in the Advanced section and didn't get a whole lot of replies.
If you want the best answer and have normal style hydraulic lifters, then you want to push the plunger down into the lifter appx. .020-.060. This can be accomplished by either using a dial indicator, or scribing the pushrod with a known mark and then scribing it again after the preload is set. Then you measure the distance between the two marks.
That's according to Crane BTW.
i did what frank, 12SCNDZ, did pretty much
with engine running, loosen rocker until i hear clacking and oil splattering everywhere, then tightened with with my fingers, until it stopped clacking (pretty much finger tight), then add 1/8 with wrench and lock the nut down.
Jesse
Jesse
When I did my cam swap, I initially set them at ½ then loosened/retightened them (one at a time) with the engine warmed up and running at ½ again.
I've had no problems, but if for some reason I have to remove the rockers, I'll do the final set @ ¼ next time.
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 14, 2015 09:20 AM
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
