How much power loss with a 52mm over a 58mm with LE2 383?
Old Jul 21, 2007 | 01:50 PM
CrazyJim's Avatar
Member
So how much power will I be giving up by running a 52mm TB w/ 38 lb injectors with a LE2 383 over a 58mm. I know lloyd recommends a 58, but I've got a good deal on an AS&M 52.
Old Jul 21, 2007 | 07:10 PM
Maro Boy Ken's Avatar
I'm not sure I'd like to know to though.
Old Jul 21, 2007 | 07:16 PM
mdacton's Avatar
Imho no loss.
If you figure the VE and your max rpm.....I bet the stock one has plenty of CFM airflow to work fine.
But then again...I have never seen a h.p. gain from a bigger TB. Even changing one while on the dyno....never sean anything. Other than making more h.p I don't see a point in it. Maybe it drives better. A 52mm should work fine.....I bet you if you stick it on a dyno and swap a 58 back to back you will not find a gain
Old Jul 21, 2007 | 07:40 PM
aboatguy's Avatar
Originally Posted by mdacton
Imho no loss.
You beat me to it! I agree 52 is probably more than big enough for 90% of modded LT1's/
But I'd probably in line for one if someone came out with a 60mm tb for lt1s
Old Jul 21, 2007 | 07:43 PM
mdacton's Avatar
yep, even though I will never need it....I just went to a 1200cfm on a vic intake. oh well
Old Jul 21, 2007 | 07:49 PM
aboatguy's Avatar
Bigger always seems better!
Old Jul 22, 2007 | 03:31 PM
CrazyJim's Avatar
Member
Thanks guys
maybe2fast
Mar 26, 2015 08:34 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
