How much power differenve between??
How much power can be had with a sold roller cam over a hyd roller cam? Is it possible to get away with a solid roller with a stock rotaiting assembly?
a solid roller doesn't give you more power
it gives you the ability to use VERY steep cam profiles and rev higher with much less valvetrian issues.
with that said, you cant rev the stock bottom end high enough to justify a solid roller, not safely in my opinion anyway..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
May 16, 2015 03:40 PM
