How much is new egr valve from dealership?
I beleive I paid around $60 but its cheaper from gmpartsdirect.com. Get an inspection mirror and look back there. There are two nuts that hold it on. Make sure you use the right size wrench to get them off, you dont want to strip these. I thought they were 13mm but mine were 1/2 inch. You may need to take off the EGR solenoid to get good access to one of the nuts. Only one nut holding the solenoid on and you can get it off with a socket. Remember how the vacuum lines go together when you take them off. Also make sure you get a new gasket.
stockssn2o
May 25, 2015 08:54 AM
