How much HP is the stock crank good for?
Old May 12, 2004 | 06:02 PM
Loadre's Avatar
I'm looking into doing a budget 355 rebuild for a 200 shot. Stock crank, Eagle forged I beams, and SRP forged pistons. I won't run but probably 4 bottles at the ABSOLUTE max through it in one year.
So what's the general rule of thumb for stock crank hp limits?
Old May 12, 2004 | 06:05 PM
RacerTim's Avatar
Theres no point in building cheap for nitrous. Either stick to NA or dish out a little extra to be safe. As for crank, I'm planning on spraying more than that but I am going with the forged ZZ4 crankshaft.
Old May 12, 2004 | 06:13 PM
96capricemgr's Avatar
Some of the Impala guys are spraying that much and more than that on whole stock bottoms, one guy has even run a 280 two stage shot on a headsa cam car putting out over 400hp NA. The stock rods are very good as well GMPP sells them as good to 450hp and the safety margin there is good.
Old May 12, 2004 | 06:15 PM
Loadre's Avatar
I think I'll be replacing the rods and pistons as I broke a piston almost completely in two and a rod into about 50 pieces.
HectorM52
Jul 30, 2017 11:46 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
hotrod 5210
Dec 22, 2014 07:28 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
