How much horspower should this setup give me???
How much horsepower should all the mods below give me and what should I run in 1/4 estimate
94 camaro z28 - 6 speed
4:10 gears
lt4 hot cam
lt4 manifold
lt4 heads
granatelli maf
pcm programmed
headers - shorty edlerbrock
off road pipe
k&n air filter charger kit
trick flow elbow
58 throttle body holley
1:6 rockers
march pulleys
How much rear wheel horspower should I be looking at
4:10 gears
lt4 hot cam
lt4 manifold
lt4 heads
granatelli maf
pcm programmed
off road pipe
trick flow elbow
1:6 rockers
march pulleys
Hey,
I'd say 345-360rwhp if all goes well.
The 1/4 estimate would be hard because there are so many factors. ie how good the car hooks, track prep, weather etc etc etc.
I think it would be safe to say that you would definately be in the 12s, I just can't say how deep it would be.
This is just my opinion....someone else feel free to chim it.
Take Care,
Tim
Take Care,
Tim
Im gonna say upper 12's ... Assuming you launch well. One suggustion for your set up though. Instead of running the Edelbrock shorties, get ASM mids ... Theyre probably the best set up if your not just gonna do long tubes ...
Should be looking at 12s pretty easy but you could make a lot more power with ported LT1 heads and the hotcam kit instead of LT4 intake/heads and have money left over. Plus if I were youd id toss out the aftermarket MAF and go with a Z06 MAF if you want something beneficial over stock.. again youd save considerable money.
Sergio
Jan 27, 2016 04:27 PM
