How much flow...
Old Jun 29, 2004 | 08:53 PM
96birdlt1's Avatar
How much flow...
How much flow does a multi ange valve job add (on average). I have these heads that have been ported and flowed around 235 at .600 lift with regular valves. I then got a multi angle valve job done and had the exhaust ports coated.I was wondering about how much flow I should be at for tuning purposes.
I don't know of any place to get them flowed around here, which is why I am asking for a estimate.
Joe
Old Jun 29, 2004 | 10:03 PM
RE AND CHERYL's Avatar
235CFM isn't much to write home about. Who ported them? I would guess the port stalled out long before .600. Whats it flow at .500 and .550?
A good valve job and performance backcut valves can add flow. I would guess about 5%+/- or so.
Old Jun 30, 2004 | 12:41 AM
96birdlt1's Avatar
I bought the heads off the forum already ported. I got them with upgraded springs and a CC305 cam for $600. I know that they don't flow as much as Lloyd's heads, but I didn't have $1200 to spend either. I'm sure that 235 + aprox. 5% will far out perform 180 CFM stock heads.
The heads did have aproximately the same flow at .550 and a little less at .500.
Besides, I was under the impression that, with a power adder (such as nitrous), the heads didn't need to flow as much because the power adder was doing the work.
I forget the numbers, but the exhaust side flowed very well, which I also was also informed that was good for heads ported with the intention of using a power adder.
Let me know if I am wrong on this, I am getting a little confused.
Joe
97SS0594
May 12, 2011 07:50 AM
posenheimer
Sep 26, 2006 11:51 PM
Roadie
Jan 24, 2006 04:04 PM
MR.ED
Jan 22, 2006 02:10 PM
30AnvZ28
Jul 7, 2005 01:55 PM
