How much deflection should a STOCK LT1 timing chain have
Old Jan 18, 2006 | 11:04 AM
BlackScreaminMachine's Avatar
I just pulled the lt4 HC last night out of the 383 for Bret's cam. I was looking at the timing chain and I was wondering. I pushed on the side of the chain and it moved about 1/2". To me it seemed a bit much but I would like other people's opinion. The timing chain had about a est. 35-40k on it with me doing 25k of the miles on it.
Old Jan 18, 2006 | 12:06 PM
mattbailey's Avatar
Re: How much deflection should a STOCK LT1 timing chain have
Sounds pretty normal to me. Chains start to strech as soon as they are rotated.
Old Jan 18, 2006 | 02:30 PM
93black-ta's Avatar
i believe i heard somewhere that 1/4" is the limit. i had 1/2" deflection with my new chain after a line honing so i had to get an oversized crank pulley. maybe 1/2" is o.k. though
Old Jan 18, 2006 | 03:53 PM
Yea, I wasnt sure. I am putting a Lunati single roller timing chain soon, I just neevr tore the car down to the short block and I wasnt sure.
THanks!
Old Jan 18, 2006 | 03:57 PM
WS Sick's Avatar
1/2 inch is too much, especially with a linkbelt type chain.
I replaced one once with a cloyes chain only from O'Reillys, it had OVER 1/2 inch of slack out of the box !!! I went and picked up one from the local chevy dealership and it had right around a 1/4 inch out of the box with new gears !!
Old Jan 18, 2006 | 04:05 PM
Colin91Z's Avatar
I read somewhere (probably here somewhere) that the reason for the added play in the LT1 timing chain is to keep the load on front cam bearing down because of the added strain from waterpump being driven off the cam sprocket ...but I'm no expert
Old Jan 18, 2006 | 06:09 PM
12SCNDZ's Avatar
I had to get a Cloyes oversized crank sprocket for my new Lunati chain. LT1's normally have alot of slop. The bottom gear fixed mine.
Frank
Old Jan 28, 2006 | 12:13 PM
Compstall's Avatar
Frank
What's the part # for the Lunati chain and Cloyes oversized sprocket you used?
Old Jan 29, 2006 | 12:16 PM
12SCNDZ's Avatar
Chain is Lunati part number L3193092. The bottom sprocket is Cloyes part number S505.
Frank
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
