How much can a stock rear take?
Alright i have the mods listed in my sig with the exception of a 3200 stall vig. convertor i'm installing soon. Now i want to be able to benifit from the convertor so i have ET streets. Now will my stock rear be able to handle this. How much do you guys put through yours. Like i said mods are in the sig with the dyno numbers. Thanx
You should be fine, my first 10-bolt lasted 450+ runs at the track cutting 1.5's - 1.6's, the posi was in the process of letting go, gearing was fine. I'm on my second posi and a used set of gears and still going strong with 300+ passes on it.
My best 60' was 1.49, mainly I cut in the low 1.5s to mid 1.5's right now.
I'm hoping it doesn't go out first time out. BTW it has 110k on it and the guy that had it before me was old and the car was bone stock. I know that old doesn't mean anything because my friends old man is 50 and he beats the hell out of his z06. Thanks for all the input.
my posi let go before my gearset did but the next time she lets go im investing in a 12 bolt or a 9 inch
http://community.webshots.com/photo/...70006206GxpCsl
Mine's held up fine to over 50 hard launches on drag radials, M6, ran the times below last time out. This is with 4:10's, solid pinion spacer, rear cover with preload studs and a stud kit
A4 guys worrying about the 10 bolt
When you switch to an M6 and run the stock rear then you should start worrying
The 10 bolt question is always a doozy....
I've come to realize that it just deponds on Driving Style.
I mean you could ride around with 900hp all day on the 10 bolt...but if you did some super duper Jet lee 5-6K Drop kick on the tranny at the track what do you expect?
Mine lasted for 3 seasons. The first 2 were low 13's/high 12's with 60 ft. times in the 1.8-1.7 range. It broke on the last race of the season last year when I was running 12.0's with 1.67 60 ft. times.
I'm going back with a 10 bolt next year...
GM 3.73's, Auburn posi, solid pinion spacer, and DTS girdle.
Alot of faith based on the fact that I'm throwing a 150 shot on top of the 12.0's...LOL
Frank
Frank
