How much can a 2bolt block handle?
Old Aug 6, 2003 | 12:39 PM
POSSESSEDZ's Avatar
I cannot find a 4 bolt block in michigan, But i found a 2 bolt for $200. I want to build a 383 motor and possibly use NOS,Can a 2 bolt handle this, or does anyone know were i could get a 4 bolt block bare.
Old Aug 6, 2003 | 12:52 PM
Dave Feerst's Avatar
according to everyone I talked to the 2 bolt can handle alot more than its given credit for. With studs insted of bolts it can handle about 500RWHP I told my machineist i was going to be running a 150 shot on my 383 and he said the 2 bolt mains would be fine.
Old Aug 6, 2003 | 12:55 PM
Mikey97Z's Avatar
I asked Nick at Nu-Tek this and he said he's only seen 2-bolt caps fail once, and that was on a circle track motor that was accidentally running 60* of advnce and the cap cracked. Apparently the'yre not a common point of failure.
Old Aug 7, 2003 | 12:14 PM
POSSESSEDZ's Avatar
i FOUND A 4 BOLT BARE BLOCK FOR $500.00 OR I GET GET A 2 BOLT FOR $200 IS PAYING $300 MORE FOR THE 4 BOLT WORTH IT?
Old Aug 7, 2003 | 12:20 PM
raceryan's Avatar
If it's worth it to you, no one can tell you otherwise.
Old Aug 7, 2003 | 12:36 PM
notstock4long's Avatar
Can't you swap the two bolt to a four bolt for under $300, by buying new caps or something?
Old Aug 7, 2003 | 01:03 PM
Transamdriver's Avatar
You can have the 2-bolt main splayed to a 4-bolt main. I have no idea on the cost.
Old Aug 7, 2003 | 01:30 PM
KCFormula's Avatar
A lot, a buddy of mine just had it done. But it looks awesome!
Devinfoote87
Feb 12, 2016 03:21 PM
4586
Jul 31, 2015 06:03 PM
jackpawt883
Jul 31, 2015 08:15 AM
Jlo
Jul 29, 2015 03:52 PM
alphaauto
Jul 26, 2015 04:40 PM
