How many volts does a csr water pump need?
Old Apr 25, 2010 | 05:37 PM
Critter's Avatar
I checked the voltage going to it and it was only 1.6 volts. It needs 12 right? I wasn't the one to install it so i'm making sure. The thing stopped pumping and this could b the problem. Thanks
Old Apr 25, 2010 | 05:51 PM
MikeGyver's Avatar
Test your meter across the battery terminals before taking a measurment to check if the meter is working correctly.
You should see battery voltage (or very close to) across the motor leads while it is running.
Old Apr 25, 2010 | 05:56 PM
Critter's Avatar
did that voltage was 12.6 on the battery
Old Apr 25, 2010 | 08:51 PM
Did you check the voltage with the pump connected to the wire, or disconnected? With the wire off the pump, you should see battery voltage, as noted above. With the wire attached to the pump, you either have some sort of large resistance in the circuit, or the pump motor is internally shorted.
Old Apr 25, 2010 | 09:00 PM
MikeGyver's Avatar
Check if the pump works by temporarily running power directly from the battery to the pump, measure voltage across the pump leads while running.
If this check out then you've got something funky going on with your wiring/relay.
With the pump running (at 1.6v or whatever), ground your negative voltmeter lead and starting at the battery and work your way back through the harness with the positive lead till you get to the pump.
Old Apr 25, 2010 | 11:27 PM
Critter's Avatar
I checked the voltage with the wire disconnected.
Old Apr 26, 2010 | 05:30 AM
Then you have a wiring problem, not a pump probem.
Old Apr 26, 2010 | 06:57 PM
Critter's Avatar
thanks for the help guys, it was in the wiring.
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
