How many o2 sensors?
Old Feb 1, 2008 | 08:54 AM
Turbozombie's Avatar
Is there one or two oxygen sensors for a 1994 LT1 Z28? This would be for an OBD1 car.
Old Feb 1, 2008 | 08:58 AM
ssbowtie1's Avatar
2 o2's
Old Feb 1, 2008 | 12:08 PM
The LT1 PCM controls each bank of the engine independantly, requiring an O2 sensor on each bank. The driver's side sensor is in the base of the exhaust manifold, the passenger side sensor is a bit below the exhaust manifold flange, on the Y-pipe.
Old Feb 1, 2008 | 02:53 PM
So are the sensors both the same part? Or are they different for each side?
Old Feb 1, 2008 | 02:54 PM
2000GTP's Avatar
Same part number.
Old Feb 1, 2008 | 03:56 PM
Shoebox has the part #'s for many popular LT1 parts on his website, along with a recommended source. If you have not looked over his site, take a quick tour:
http://shbox.com/1/4th_gen_tech1.html
As far as the O2 sensors, I would strongly recommend that you use only the OEM AC/Delco parts.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
