Wierd engine noise on startup help.
Old Jan 31, 2008 | 02:09 PM
camarozz95's Avatar
Ok last week I took a trip up to Gainesville to see my friend who goes to UF. the car sat for about 3 days, when i went to go leave I started the car it started right up, but i heard a sound coming from the passenger side of the engine, it sounded like if you were to knock on a hollow piece of wood its not a ticking sound though. I was like WTF!, but then it stopped after about 5 seconds everything seemed fine got on the highway drove back home no issues since then.
Then today I went to use my car it sat for 3 days I go to start it makes the same sound then stops after 5 seconds. So my question is what could be causing it, and could it be the signs of something serious. Thanks
Old Jan 31, 2008 | 02:24 PM
mrmint69's Avatar
I would have someone start the car and get as close to the noise as possible and see where its coming from. A video with sound would help also.
Old Jan 31, 2008 | 02:43 PM
camarozz95's Avatar
yeah the problem seems to be the car has to sit for a couple days it seems otherwise it doesn't do it, and it stops so fast I couldn't get out to see where exactly it was coming from.
Old Jan 31, 2008 | 07:45 PM
mrmint69's Avatar
If it only happens when it sits for a long period of time and no other it might be something like the pulley or belt.
Old Feb 1, 2008 | 08:27 AM
vette96's Avatar
does your car still has the catalytic converter on it??
it might be the time to check...
Old Feb 1, 2008 | 04:51 PM
camarozz95's Avatar
No the car doesn't have cats. The car has yet to make the noise again, so I'm almost positive it has something to do with the car sitting and not being used for more than two days. It almost never does sit so I'm guessing I won't be able to diagnose it unless I'm not going to use the car for a couple days..
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
Lions3
Apr 11, 2003 10:55 AM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
Omega9
Aug 2, 2002 12:33 AM
