how many mods before tune on SD 1993
Old Nov 13, 2007 | 10:06 AM
knute_gis's Avatar
I have owned 2 1995 fbodies with bolt-ons and a tune.
I am looking at buying a 93 trans am auto, and was wandering what all bolt-on's can be done before you have to tune it?
I don't know much about Speed Density and I'm not sure if I should buy the car or not.
Thanks for any help
Old Nov 13, 2007 | 11:55 AM
ricehammer's Avatar
Basically everything up to a new set of gears, if you consider that a bolt on. Some say that you need a tune for LT headers. Wouldn't know, I did headers/cam/tune at the same time. If it were me, I would get a new tune with bolt on's anyways because a tune is pretty reasonable as far as cost goes for the added performance.
Old Nov 13, 2007 | 12:02 PM
Pyrodawg's Avatar
www.speeddensity.org that website is specific to 93 fbodys we can answer most all questions about the car...
for a tune we need to have a chip burned... I obviously have a pcmforless... good prices and good service
id suggest getting a tune after longtubes.. most everything else you should be fine but a tune would bring the most out of it... plus you can always send the chip back for a retune...
also with longtubes, converting to heated O2 sensors helps... the owner of sd.org makes a conversion kit for us
Old Nov 13, 2007 | 12:03 PM
2000GTP's Avatar
A tune isn't mandatory for headers, but as mentioned, the tune does make for a good "bolt-on" mod in itself and can offer a variety of benefits aside from the power gain.
Old Nov 13, 2007 | 12:09 PM
knute_gis's Avatar
So cold-air, throddle-body, catback, underdrive-pulley are OK
Sounds like its about the same as mass air!
Do you guys usually have the car Dyno-tuned or is a mail order chip good enough with bolt-ons and longtubes?
Thanks, Kris
Old Nov 13, 2007 | 12:17 PM
2000GTP's Avatar
A mail order tune is more then adequate for bolt-ons and long tubes.
Old Nov 13, 2007 | 04:21 PM
neil350's Avatar
I did it after long tubes, should have been the first thing I did. Was worth it for the adjusted fan settings.
Old Nov 13, 2007 | 04:29 PM
<Puck>'s Avatar
My 93 did not run very smooth after longtubes until I got the heated o2 conversion. Besides smoothing out the idle, it also helped with my a/f.
Not technically a neccessity to run, but it helped a hell of a lot.
Old Nov 13, 2007 | 09:30 PM
lethal93ta's Avatar
I had just about every bolt on and a supercharger running on a stock tune for over 2 years, not advisable but I did it and ran low 12s on a weekly basis at the track.
Old Nov 14, 2007 | 05:00 AM
Crows89RS's Avatar
Don't necessarily need a tune. Of course, if you have the extra money, might as well. As others mentioned, it will help with things like AFR, idle, etc. 93's are sometimes a pain in the *** for local hands on tuners though if they can't burn ePROM chips.
Old Nov 14, 2007 | 04:46 PM
neil350's Avatar
Mine did the same thing idled like I had a small cam when I would get to stop lights, wouldn't ever die but was annoying, after the heated conversion car idles smooth again.
anmar A
May 2, 2015 06:59 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Sarahrope64
Nov 27, 2014 11:17 AM
