How many miles is too high for LT1?
Old Jun 5, 2004 | 03:02 PM
83TransAm's Avatar
I saw an ad for a guy who has a 95 Z28 with 117K on it? Is that really high for an LT1? At what mileage does the engine start wearing out???
Steve
Old Jun 5, 2004 | 03:14 PM
sabre81's Avatar
depends on how well it was maintained as well as how it was driven. these engines can last a long long time. Check the basic things you would check for when looking over a car. Check to see what parts have been replaced. Specifically the optispark, fuel pump, water pump. these are a few things that if failed could cause a sudden weight loss in the wallet.
Old Jun 5, 2004 | 03:20 PM
1994CamaroZ28's Avatar
my 1994 z28 has 167k miles on the engine only big problem i have is i blew my exhaust manifold gaskets so i just ordered a set of headers.
she leaks a bit of oil but canot complain.
one thing to look at is transmission
Old Jun 5, 2004 | 03:41 PM
stereomandan's Avatar
Things that I would ask about:
Intake manifold gaksket
Optispark
Waterpump
fuel pump
Those are the most common things that fail, like others have said.
I have 62000 on my LT1 and have replaced my waterpump, fuel pump (under warrenty), and my intake manifold gasket (under warrenty)
Feel behind the engine, where the intake manifold meets the block. If there is oil back there, it most likely has an intake manifold leak.
Drive the car and listen for anything that sounds abnormal. The LT1 is a fairly smooth running engine. It should have a very very mild shake at idle, almost unnoticable.
117k is not a ton of miles for the LT1, but it's still quite a few on any car. If you plan to mod it, it makes less of a difference because you end up changing so many engine parts anyways.
Dan
Old Jun 5, 2004 | 04:14 PM
pasmado15's Avatar
over 200K
I'm currently on 258,000 miles with only the water and fuel pumps in need of replacement - and that was a few miles ago. Treat her like a lady and she will always perform...
Old Jun 5, 2004 | 04:41 PM
YZF/LS1 Freak's Avatar
I have 106k on my 96 Z, well taken care of, NONE of the seals leak or seep a thing and it burns no oil, with the open air box and a light optioned car I can hang with LS1's I can't win but I can hang with them. Most of them have half the miles I do also.
Old Jun 5, 2004 | 05:59 PM
1984camaroz28's Avatar
110k
bought my car with 100k on it moded it and spraying it with a 100shot never replaced anything and byno means am i easy on it
Old Jun 5, 2004 | 07:44 PM
a mean 94z's Avatar
Bought my car in November with 93,000...now she has 98,600
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jun 23, 2016 08:42 PM
