How Many HP? (A/C Delete)
I would have to live in a damn cool climate to give up AC for a minicule gain in the 1/4m. However, if I were building a race car of course I would remove it. The gain would be small, but so are most gains - luckily, weight reduction gains are additive. But as stated, they will be small for this mod in and of itself. To each his own!
Rich
ps: I just saw bracket racing. If it's not heads up racing I can't see it.
Rich
In theory, it might gain you a tiny amount of RWHP due to reduction in rotational mass... Probably not even 1 HP though... There isn't even much gain from going with a light weight flywheel and that is both a larger weight reduction and the reduced weight is much farther from the center of rotation... I also suppose that an aluminum driveshaft in theory gains a little HP over the steel driveshaft, but it just isn't significant.
I'm sure you can cut 30 to 50 lbs off the car if you delete all the AC and Heat related components... Of course if you still street drive the car, I doubt it's worth the headaches...
I participate the in the NHRA Summit Series and points race which is very competitive and a lot of fun (even more fun if you’re winning). The Summit Series also hosts several special evens (National Dragster Challenge, King of the Track, Etc.) as-well-as the Division Finals (7 Divisions total) and National Finals at Pomona.
Check-out this link.
http://www.nhra.com/aboutnhr/etseries.htm
WD
All forms of racing have the same connundrum: how to make racing affordable, yet fun and competitive. Heads up racing often comes down to "he who spends the most money wins". Now, spending doesn't guarantee success, as Toyota knows and any follower of F1 can confirm. But you have to have a competitive budget to be competitive. Hence bracket racing in the drags and "spec" classes in amatuer road racing, etc. Some pro series have become almost "spec", classes such as the IRL. Even in F1, the biggest budget racing series of all (Toyota est. budget is $150,000,000 annual) there is one tire supplier (in effect, a "spec" tire) and they are going to a spec ECU.
There is something inherently unsatisfying about not making every pass as fast as you possibly can. But the alternative would lead to very uncompetitive racing except for the couple of biggest spenders. So, the term necessary evil is appropriate.
Rich
Rich
