How many hours to replace an opti
Old Dec 11, 2007 | 02:29 AM
  #16
lt1rx798's Avatar
i got you guys beat.... ive had to do it soooo many times, im down to 15-20. i do have a slight advantage though. mine is in an rx-7.
btw- i can change all my plugs in about 10 mins., and i still have a/c!!! -no, really.....
Old Dec 11, 2007 | 05:12 AM
  #17
shock6906's Avatar
Wow! If I could do it in under an hour I wouldn't even hesitate to do it myself.
Old Dec 11, 2007 | 10:05 AM
  #18
My Iroc Z28's Avatar
Once you do it enough everything can be done faster. I've swaped opti's in about a hr and plugs with stock manifolds in 45 mins. Plus it helps when you have custom tools to help make the job easier.
Old Dec 11, 2007 | 04:29 PM
  #19
shock6906's Avatar
Well I've decided to do it myself. The fans are out, everything's disconnected, the plug wires are off, and I'm just about to the point of getting the water pump off. I'll get to that tomorrow. Also, that'll be when I pull the crank pulley off. What all gaskets do I need for this job? I have two water pump gaskets. What else?
Old Dec 11, 2007 | 04:34 PM
  #20
That should cover it. if im not mistaken
Old Dec 11, 2007 | 05:41 PM
  #21
rcantrellz28's Avatar
Yep, just the pump gaskets , since your already at it go ahead and do the coil/module cooling upgrade( space them away from heads) . If you havent already done this?
Old Dec 11, 2007 | 05:48 PM
  #22
shock6906's Avatar
I haven't already done this. I haven't even heard about it to be honest. Do you just use some washers? How far away do you space it away from the head?
Old Dec 11, 2007 | 05:58 PM
  #23
Yea, you just use some spacers about 1-1/4 inches out . This will help keep your module and coil cooler , no proven gains to power that I am aware of , but it should extend the life of both. I learned this at shoebox's awesome site .
Old Dec 11, 2007 | 06:04 PM
  #24
I need to correct myself Alan , it would be about 1/2 inch....sorry
Old Dec 11, 2007 | 06:13 PM
  #25
Check out shoebox's site for the info on the mod.
Old Dec 11, 2007 | 06:18 PM
  #26
shock6906's Avatar
Cool. Thanks guys. I'm hoping to get the opti bolted in tomorrow. I'm planning on finishing everything up on Thursday. It sucks only have ~2 hours to work on it each day. Wouldn't be a problem if not for daylight saving time.
Old Dec 12, 2007 | 12:59 AM
  #27
86formula's Avatar
just took me 2 hours from start to finish including opening up the opti and loctiting the rotor screws. make sure you to that btw because they have a habit of coming loose.
Old Dec 12, 2007 | 05:00 AM
  #28
shock6906's Avatar
Oooh, thanks. I suppose I'll need to pick up some loctite then.
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
pologreen97z
Dec 2, 2014 10:42 AM
