how long should SES codes appear after pulling the PCM BATT fuse for 30 seconds?
how long before SES codes appear after pulling the PCM BATT fuse for 30 seconds?
Hey guys,
just wondering how long it typically takes for SES codes to appear after pulling the PCM BATT fuse from inside the car? Just wondering because i had code P0160 before i fixed the harness and pulled the PCM BATT fuse. Just wondering!
thanks
thanks
Re: how long before SES codes appear after pulling the PCM BATT fuse for 30 seconds?
Originally Posted by pillagenburn
Hey guys,
thanks
thanks
so how do i tell if its still there?
should i drive it around more?
This sucks.... seriously haha stupid rear o2 sensors!
would an OBD2 code scanner pick up these codes?
thanks
thanks
Re: how long should SES codes appear after pulling the PCM BATT fuse for 30 seconds?
thanks
thanks
Performing a GM OBD-II Driving cycle:
Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 122°F (50°C) and within 11°F (6°C) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 55mph (88km/hr) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 20 mph (32km/hr). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
Accelerate. Accelerate at 3/4 throttle until 55-60mph (88-96 km/hr). This will perform the same diagnostics as in step 3.
Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Gtpguy
Jan 26, 2015 04:50 PM
owen66
Nov 30, 2014 04:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
