How long to replace spark plugs and wires?
Old Aug 8, 2007 | 07:07 AM
  #16
Harvey's Avatar
Question
Originally Posted by andysc
Hi there
I have a set of spark plug sockets that have a notch cut out of one of the sides, they are for headers, but are great for these cars. The slot allows you to slip the socket over the spark plug at a angle instead of straight on. They are also cut down so they are short in length.
I then use a flex head ratcheting ratchet and it makes life soooooo much better. Let me know if you would like
to know about these.
tia
andy schuck
Got pictures?
Old Aug 13, 2007 | 08:39 PM
  #17
andysc's Avatar
I'll get some pics up in a couple of days.
tia
andy schuck
Old Sep 8, 2007 | 05:22 PM
  #18
jefferino's Avatar
Screw pictures....where can I get some of these?
Old Sep 8, 2007 | 06:12 PM
  #19
Hark_z's Avatar
How are the plugs numbered again?
7 8
5 6
3 4
1 2
Like that looking from the front of the car? I cant get to what I think is 5 and 6. I have pace LTs and I cant even get the wires off..theres absolutely no room to reach there?
Old Sep 9, 2007 | 03:24 AM
  #20
TGK's Avatar
TGK
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
I haven't done the wires before, but my first time doing the plugs took probably a little less than 4 hours. That's without removing anything.
Old Sep 9, 2007 | 03:26 AM
  #21
TGK's Avatar
TGK
7 8
5 6
3 4
1 2
No, from the front of the car it's -
8 7
6 5
4 3
2 1
Old Sep 9, 2007 | 03:28 AM
  #22
TGK's Avatar
TGK
Originally Posted by 1SlowFormula
Did you count the time it took you too pull the starter, or were you actually able to get the #7 from the bottom without removing the starter?
How small are your arms?
The starter isn't in the way of plug #7. You've got plug #7 confused with plug #8. Also, I changed out #8 from below without removing the starter, or anything actually.
Old Sep 9, 2007 | 11:54 AM
  #23
tfalconier's Avatar
i did both in like an hour my first time before i had my delteq and headers, i dont have the slp special stocket, and ive been working out every day for years so my arms arent small by any means, i found the hardest part was getting the wires into the metal guides, you can get most of them from the bottom.
p.s taking the starter out shouldnt take more then 5 minutes
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
IRABuss
Sep 7, 2011 09:08 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
