How long does it take YOU to change your spark plugs?
Old Oct 7, 2004 | 08:42 AM
  #16
Demus's Avatar
Re: How long does it take YOU to change your spark plugs?
As everyone else has said, driver's side is a since. The passenger side is much more difficult. _THE_ tool for the job is a spark plug socket and a stubby gear wrench (but a regular combination wrench will do just fine). Just slide the wrench over the hex end of the spark plug socket and you're laughing. The first few times I did the plugs I tried all sorts of crap, like long extensions, u-joints, and all that bs. No way anymore. If you have everything all laid out for you, you can do it in 30 mins. But if you have to sit there, grease the plugs, gap the plugs, apply dielectric grease to the boots, etc. etc. it's going to take closer to 1 hour 30 minutes.
Old Oct 7, 2004 | 08:58 AM
  #17
MarkyMark's Avatar
Originally Posted by madwolf
Here we go again....
"Yea, I can change mine in 15 minutes with one hand, smoking a cigar and a double whopper with extra onions in the other hand....hmmm now I might as well drop the engine through the bottom in the next 30 minutes to make things easier..."
I'm sure the times will get lower and lower as you get more replies to this post....
Honestly, it was the first thing I did on a 4thgen. Took me half a day to do wires and plugs the first time. I can probably do it in under 2 hours now....(stock manifolds)... less with the long tubes.
That was too funny....
Took me a good half a day, but now I can do it alot easier since I have a little more experience. I am putting on pacesetter longtubes this winter and I have heard the spark plug access is great.
  #18
30696bird's Avatar
Originally Posted by CrAkD X 95TA
good luck man. I ended up breaking one of the plugs off inside the block trying to get it out. ended up having to bring it to a shop and have them get the broken one out and do the rest of em. Now that ive had my engine rebuilt and the SLP's put on im hoping to never have to do it or when i do ill probably just pay to have it done.
How do you break one off in your block???? Your plugs are in your heads.
  #19
tryintogofast's Avatar
I actually changed my plugs last night in prep form the nitrious install and overall wise it took about an 1 hour 30 min. All but the driver side rear can be gotten to from the top. Last one from the bottom. Heh I'm not even going to try changing those plugs wires until the lt's go in!! But yeah hour and a half and a few layers of skin and you'll be there.
Mike
Old Oct 7, 2004 | 09:03 AM
  #20
WOT's Avatar
WOT
About three hours the first time with stock manifolds. The plug wires however (stock location) were a real PITA.
Old Oct 7, 2004 | 09:33 AM
  #21
96ZRide's Avatar
With FLP Longtubes, it took me about 3 hours, when I first did it. A 3/4 ratchet wrench and the SLP plug socket are KEY!
I could probably do it inside of two hours now, having already done it once.
Old Oct 7, 2004 | 10:03 AM
  #22
ksmyss's Avatar
45 minutes or so depending on beer breaks. its really easy with slp shorties, true duals and no emisions. all i use is a short 5/8" wrench and a s shaped 5/8" wrench
Old Oct 7, 2004 | 03:20 PM
  #23
regorih inHous.'s Avatar
took me 2 weeks
Old Oct 7, 2004 | 04:45 PM
  #24
Kataklysm's Avatar
With slp headers it took me 8 hours. With MAC headers I can do it an an hour now.
Old Oct 7, 2004 | 05:20 PM
  #25
Zepher's Avatar
I can do mine in about 15 minutes if I wanted to.
I've got longtubes and my LT1 is mounted in my 3rd gen Trans Am.
Old Oct 7, 2004 | 06:54 PM
  #26
turbo_Z's Avatar
I can do an opti swap in less time than it takes me to change all my spark plugs. Having one of those chopped down sockets really helps and w/o one I dont think Id ever get them all replaced.
Old Oct 7, 2004 | 07:04 PM
  #27
ShawnMacAnanny's Avatar
Where is the rest of your car
Old Oct 7, 2004 | 07:05 PM
  #28
sallmon's Avatar
Cool Re: How long does it take YOU to change your spark plugs?
On my stock 95 Z28 it takes about 3 hours, including lifting, tool gathering and cleanup.
If you are doing a spark plug change on an F body LT1 for the first time, I STRONGLY recommend you get a friend to help ( the passenger side is such a pain, you might destroy engine parts without a witness to calm you down!).
Have to say, I'd like to find the engineers who designed this engine and kick their *** from one side of Michigan to the other side of Kansas.
Having said that, I love the power and the torque!
Old Oct 7, 2004 | 07:12 PM
  #29
Makes sense being that they were made in Canada
Old Oct 7, 2004 | 07:29 PM
  #30
Zepher's Avatar
All over the garage and on the floor.
