How to lift car to weld SFC's?
Old Feb 1, 2004 | 11:04 AM
Xride's Avatar
I'll be getting some subframe connectors here for my new car (kenny brown double diamonds are winning, or the SLP ones again)
but for welding them up I dont want to go to the same guy as I didnt like how his welds just broke when my car was hit.
I found a guy that can do it, but he only has a y lift, a Y shaped lift on each side, know what I mean?
I dont want the frame to be twised at all when I weld them up, so I dont think I can use that kind of lift, but what if I used jack stands? and where would I put them?
if I jsut tacked them in or even jsut did half the weld could I then put it up on the lift and do the rest?
Or shuld I really find a guy with a pit to do it?
would mean an exhaust shop and a guy doing his first SFC install...
Old Feb 1, 2004 | 11:12 AM
Camaro_Maniac63's Avatar
You have to support the car by its wheels while lifting if you are going to weld SFCs in. That way, you are actually simulating real road conditrions, where all your tires are contacting the pavement. Good luck.
Old Feb 1, 2004 | 12:54 PM
Xride's Avatar
so If I lift it up and put the wheels on like cinder blocks or something that would work? Is that very safe?
I dont mind welding while being on a creeper, but gotta get it high enough to get under the damn car, haha.
Old Feb 1, 2004 | 01:52 PM
KenP's Avatar
Do not use concrete block, that is not safe. I used car ramps at all 4 corners. Drove the front up on Rhino ramps and then used a big floor jack to put the back end on another pair.
Old Feb 1, 2004 | 02:14 PM
Xride's Avatar
I only have two ramps.... is there something I could use for the back that would be good?
Old Feb 1, 2004 | 02:27 PM
LPEdave's Avatar
A stack of 2x8's will work, or on the rear you can certainly use jack stands under the axle, which is that same thing.
Dave
Old Feb 2, 2004 | 01:43 AM
Xride's Avatar
Thanks,
ramps in the front and jack stnads under hte axel in the rear it is.
one last question, hows the best way to prep for the welds (wire wheel clean? or grind a bit?
and should I tig, mig, sub arc...
Old Feb 2, 2004 | 02:04 AM
stevil's Avatar
Thats how mine was supported. Prep, the SFCs were put into place, marked off the edges where it needed welded, then used something to grind the paint off, I forget. Whatever you have. Also remove paint on the SFCs. He used flux core on mine, but that was the only option. Mig would probably be better. Don't forget to disconnect the battery. Paint the welds afterwards to prevent rust. The fuel lines are sort of close on one side, don't weld those.
LeftoverChinese
Jan 14, 2024 03:03 PM
1775.Z28
Jan 11, 2015 10:51 AM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
