How to launch with a stall?
Old Mar 13, 2003 | 08:35 AM
  #16
grygst76's Avatar
If you know your cams rated range go 250-500 rpm above it by holding the throttle in i.e 1600-4600 go 2000 if the tires can hold it!! When I dragged my 76 I used to hold the e-brake in to stop the tires from letting go it was a pain in the dairyair but I stayed consistent at 10.3@127 to 10.6@124. Practice where you won't get busted and just choose your own method, and take your front stabilizer bar off and set your camber to -1 degree in the rear so the tires will bite better.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
