How To Install New o2 sensors.
Old Nov 22, 2005 | 09:05 PM
pHEnomIC's Avatar
What is the best way to remove and insert new o2 sensors? The passanger side seems especially difficult to reach. I plan to burrow a o2 sensor socket from autozone to help, any tips?
My sensors don't have antiseize on them, can i use any kind?
Old Nov 22, 2005 | 09:07 PM
CamaroSS30thAnn's Avatar
Re: How To Install New o2 sensors.
just spray it down alot with PB blaster or ur fav rust remover
u just have to use a little finess and u can get it out
Old Nov 23, 2005 | 01:13 AM
cas0484's Avatar
I second that....spray alot of WD-40 or whatever on it and let it soak a bit, then slowly do the best you can. Fortunatly, I had no problems removing mine. Goodluck. Its a fairly straightforward R&R.
Old Nov 23, 2005 | 05:02 AM
FuryZ28's Avatar
Just have the right extensions and maybe a universal joint or flex head extension to help get you in that odd angle...
Old Nov 23, 2005 | 05:16 AM
1racerdude's Avatar
Get a 7/8 combination wrench and a hammer to break it loose. Put anti sieze on the new ones and next time they will come out.
Old Nov 23, 2005 | 05:34 AM
They come out easier if the exhaust system is hot. Your skin may not like it that way, though
My AC/Delco sensors indicated on the package that they were pre-coated with electrically conductive anti-sieze, and that no additional material should be used. You do not want to get any foreign materials on the sensor, including the outside, where air needs to enter the sensor to generate the small voltage produced by the zirconium membrane.
Old Nov 26, 2005 | 02:59 PM
pHEnomIC's Avatar
I did the drivers side and it wasn't that bad. Anyone got some tips for the passenger side? Did you get it from the top or bottom and how did you have it set up? I can get the socket on it from the top but no matter how i set my extensions and wrench up, I cant get them to ratchet at all.
Old Nov 26, 2005 | 04:48 PM
pHEnomIC's Avatar
Nvm, got it, whew that was hard....
Ended up doing o2 socket, u joint, 1 foot of extensions and broke it loose with my impact wrench above the engine. Then just unscrewed with my hand.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
