How to install new dash pad?
Old Feb 17, 2004 | 02:56 PM
Indy93Z28's Avatar
I just bought a new dash pad for my Z28 and I'm trying to figure out how to remove the old one. Any help would be appreciated.
Old Feb 17, 2004 | 03:36 PM
1msfyter's Avatar
Pretty easy . It is held on by heavy duty velcro and I believe 3 plastic posts . Just pry it up in two places with 2 wide putty knives it will pop right up. Also you will have to remove your A pillar trim .
Old Feb 20, 2004 | 04:15 PM
Indy93Z28's Avatar
I see two alan screws on the a-pillar and a metal rod connecting the a-pillar trim to the t-top secure trim... There doesnt seem to be room to remove the screws?
Old Feb 20, 2004 | 05:22 PM
1msfyter's Avatar
after removing the T top on the A pillar are 2 phillips screws holding the A pillar plastic piece in, once removed tug the A pillar plastic off. Its held in by 2 metal clips. Pops right off
Old Feb 20, 2004 | 05:26 PM
Don't Look Back's Avatar
You don't need to remove the A pillars. I had mine out a few times, and never did it. One word of advice though. Do not, under any circumstances, push in the middle of the pad with force. Mine cracked in half cause I was dumb, and didn't realize what I was doing.
Old Feb 20, 2004 | 05:27 PM
Indy93Z28's Avatar
Well the a-pillar trim is flush up again the edges of the dash pad... not really any room to work with the trim there
Old Feb 20, 2004 | 05:31 PM
True. It's proably better to remove the A pillars, but the dash pad will slide out without removing them, and will fit back in. You may have to manipulate it a little to get it back in. Just saying how I did it. If you don't mind removing the A pillars, its a better (Less chance of breaking) way.
Old Feb 20, 2004 | 05:45 PM
1.8ttolt1's Avatar
where did you get the dash pad?
Old Feb 20, 2004 | 06:13 PM
Indy93Z28's Avatar
Jason Cromer
Richardan15
May 30, 2015 08:36 AM
nikko
Dec 2, 2014 03:43 PM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
